I think mail server is not saving SSL when added.
Please can someone help me!!!
This is what I get when adding SSL to a domain.
Please I am really frustrated as my clients are leaving my services.
Please someone should help!!
Post link:
Detailed problem description:
Thank you for your kind support so far. You are the best.
Please see error above when I tried adding a new email account via roundcube.
My steps
But I get this error on trying to access.
Please what could be this problem and solution please.
Hello, what version of mysql are you using? Versions below mysql 5.6 are not supported
aaPanel_Kern I am using the most updated version.
What do I do please to solve this?
It is recommended that you tell us what version of mysql is
aaPanel_Kern MySQL 5.7.44
Post link:
aaPanel_Kern I gave it my aapanel details yesterday. Informations still valid. Please kindly proceed
Hello, please update the one-click deployment to version 1.2. Is this a solution?
aaPanel_Kern I have updated but issue still persist.
Please proceed with the aapanel information I sent yesterday.
Hello, I suggest you check if the database you are using exists? Also need to delete it permanently from recycle bin
I tested kktest.com and it is normal
Ricosoft
Please can you help me add
I have done everything you said but still can't access url
Hello, if it cannot be deployed, it is recommended that you manually modify the mysql configuration of the configuration file. Is it possible?
aaPanel_Kern please I am tired of these issues.
Can you please help me do this.
Why I'm I facing all these issues??
Hello, you can try to modify the configuration file or download the official website program to deploy manually.
aaPanel_Kern please can you please deploy this for me.
The customer is suing me already. This is weeks now.
Please
Just change BT_DB_USERNAME and BT_DB_PASSWDRD to the database user and password.
aaPanel_Kern I can't find that
