- Edited
thanks my friend but the problem still exists
requests.exceptions.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
aaP_titanyusfi123 corrigiu ou nao
Pra mim começou ontem apenas em novas instalações...Já tentei de tudo!
lonardonetto For me it only started yesterday in new installations...I've tried everything!
Lucifer any solution for this?
Lucifer For me it only started yesterday in new installations...I've tried everything!
sub domain brandnew.aapanel.com is down now
https://prnt.sc/NIFEf_zw7zJQ
Just have restarted the panel and got this error, seems like their a record is missing. that URL is unavailable worldwide. so, I'm using previous ip addressed and it has fixed it. I will back it to normal when their a record is online again.
Reinstalled the server with Debian 11:
-> Installed AAPanel.
-> Changed the host file
Still getting error: json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
REQUEST_DATE: 2024-01-07 11:02:46
Even tried to clean browser cache/history and incognito mode but nothing works even multiple times shift/f5
jxng it doesn't work for me.
edward_nguyen what is not working? ?
Depimios
I updated vhosts as shown in the picture, but it is not fixed
UPDATE: THE FIX (ATM) DOES NOT WORK FOR FRESH INSTALLATIONS!
I'M DOING A COUPLE TESTS AND WILL KEEP YOU GUYS INFORMED
FOR EXISTING INSTALLATION, BASIC PROCEDURE AFTER MODIFYING /etc/hosts
IS:
@Lucifer @edward_nguyen @carlita @aaP_titanyusfi123 @aaP_abdillah_pandu0
jxng Thank you a lot for this.
I think they will continue to fail again. And we will do so as a temporary solution.
Btw, I just created another VM instance and then installed Aapanel but other strange issues appeared.
