aaPanel_Jose @aapanel_sniper
I have realized that it's added when you request for SSL.
Any domains without an SSL don't have the security headers.
Please fix it and remove "preload" on HSTS
10 months later
x3inspire
Hello, add the following to the configuration file of the website and restart OLS: Please backup before modifying
context / {
allowBrowse 1
extraHeaders Strict-Transport-Security "max-age=31536000; includeSubDomains;preload"
rewrite {
addDefaultCharset off
phpIniOverride {
    2 years later
    aaPanel_Kern Hello, whatever I do, it doesn't get disabled. I also removed the HSTS code. Do you suggest that the problem might be due to nginx 1.22?
    I have Debian 11
    Please tell me if it's not adjustable so I can stop doing the various settings because I'm confused
    I saw that you asked someone before
    Did you activate web speed? Yes, I activated it and then deleted web speed
    Content-Type: text/html; charset=UTF-8
    Connection: close
    X-Redirect-By: WordPress
    Strict-Transport-Security: max-age=63072000; includeSubdomains; preload
    X-Cache: HIT From domain.com
    Cache-Control: max-age=0
    Nginx-Cache: HIT
    Last-Modified: Monday, 15-Jan-2024 16:18:15 GMT
    X-Frame-Options: SAMEORIGIN
    X-Content-Type-Options: nosniff
    X-XSS-Protection: 1; mode=block
      Hello, you need to test this yourself. Do you use incognito mode to access? Do you want to restart nginx after modifying the configuration?
      shahinsafari
        aaPanel_Kern 1- no 2- yes
        See, I removed it from this section, but it does not apply
        add_header Strict-Transport-Security "max-age=63072000;";
        Hello, I thank God
        My problem is solved
        See, I deleted the site without deleting the database and root, I rebuilt the site, but I did not do this from the Wordpress deploy section, is there a problem?
        2- Could I do the same thing I did using the Wordpress deploy method?
        @aaPanel_Kern
        I also put it with the Wordpress deploy method, thank you
        Put the possibility of deleting and editing in the aapanel forum so that when the problem is solved, we will delete the article so that it does not take up your time
          aaP_syedsabahathussain
          Hello, sorry, I replied late, my server exploded 🤣
          Your site may not be redirected correctly
          or ssl is not activated correctly, re-enable the ssl certificate
          2 months later
