• Support
  • aaPanel 7.0.11 docker panel failure
After updated to 7.0.11 docker panel not working suddenly, and it seem the panel unable retrieve my system's docker status, I have tried to start and restart by clicking the button on the panel. Unfortunately, it still not working.
    Hi, I managed to do it in sudo.
    Here is the output:
    Collecting docker
    Using cached docker-7.1.0-py3-none-any.whl.metadata (3.8 kB)
    Collecting requests>=2.26.0 (from docker)
    Using cached requests-2.32.3-py3-none-any.whl.metadata (4.6 kB)
    Collecting urllib3>=1.26.0 (from docker)
    Using cached urllib3-2.2.3-py3-none-any.whl.metadata (6.5 kB)
    Collecting charset-normalizer<4,>=2 (from requests>=2.26.0->docker)
    Using cached charset_normalizer-3.4.0-cp312-cp312-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (34 kB)
    Collecting idna<4,>=2.5 (from requests>=2.26.0->docker)
    Using cached idna-3.10-py3-none-any.whl.metadata (10 kB)
    Collecting certifi>=2017.4.17 (from requests>=2.26.0->docker)
    Using cached certifi-2024.8.30-py3-none-any.whl.metadata (2.2 kB)
    Using cached docker-7.1.0-py3-none-any.whl (147 kB)
    Using cached requests-2.32.3-py3-none-any.whl (64 kB)
    Using cached urllib3-2.2.3-py3-none-any.whl (126 kB)
    Using cached certifi-2024.8.30-py3-none-any.whl (167 kB)
    Using cached charset_normalizer-3.4.0-cp312-cp312-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (143 kB)
    Using cached idna-3.10-py3-none-any.whl (70 kB)
    DEPRECATION: Loading egg at /www/server/panel/pyenv/lib/python3.12/site-packages/PyMySQL-0.9.3-py3.12.egg is deprecated. pip 24.3 will enforce this behaviour change. A possible replacement is to use pip for package installation.. Discussion can be found at https://github.com/pypa/pip/issues/12330
    Installing collected packages: urllib3, idna, charset-normalizer, certifi, requests, docker
    ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
    oss2 2.17.0 requires aliyun-python-sdk-core>=2.13.12, which is not installed.
    oss2 2.17.0 requires aliyun-python-sdk-kms>=2.4.1, which is not installed.
    httpx 0.27.0 requires httpcore==1.*, but you have httpcore 0.17.3 which is incompatible.
    Successfully installed certifi-2024.2.2 charset-normalizer-3.4.0 docker-7.1.0 idna-3.7 requests-2.32.3 urllib3-1.26.18
