- Edited
Testing files: https://prnt.sc/ufywy2
Diagnosis from Wordfence support, there is the problem:
Ubuntu 20 with OLS: https://prnt.sc/ufyxeb
Debian 10 with Nginx: https://prnt.sc/ufyy2x
With cURL have any plugin problems:
https://prnt.sc/ug1bbw
Hello, is it working smoothly? Has this cURL issue been fixed?
I want to migrate to OpenLiteSpeed, I am currently using nginx, but I am afraid given the problems reported above.
I appreciate it.
thanks XD
now iam speed LOL
rafamarchetti if you came from "nginx" it will be some error that you must fix it manually since the nginx and OLS have some (big) different
but if you came from apache, i think you will fine
I am using Apache + WebSite Speed 2.9 + Memcached 1.6.9 Builtin apps.
Seen very good results on WordPress Cache and get GTmetrix Grade A .
https://gtmetrix.com - https://prnt.sc/12jpgiz
x-cache: https://prnt.sc/12jpeub
+rep for the tutorial. Since aaPanel at the current state lacks a built-in firewall for Openlitespeed, We wordpress users wouldneed Wordfence protection. In the future, I wish aaPanel team can add more features/supports to Openlitespeed Webserver.
Yamiraan
Yes, its a free plus, I think You can install it automatically in aaPanel only click on add Redis extension. When no, he warn You to before install in App manager.
Dont forget set password too and limit memory for Redis (example of 8GB ram is 2,5GB). Redis can eat 6GB and more without problem.
In Wordpress plugin Litespeed cache set a database key for each site (start from 0, 1, 2... to 16 in default).
I try before free Redis WP plugin but without paying for premium is terrible(not max speed) . Litespeed plugin make all work perfectly at maximum.
