Hello, yes, but some software and plug-ins cannot work on arm.
Minimum requirements
I'd been using aapanel with hetzner ARM server for last 1 year without problem on Ubuntu 20.04.
- Edited
aaP_hareeshnarayan1982 I'm having problems installing MariaDB, it says OK, but I haven't installed anything.
Ubuntu 22.04.4
- Edited
aaP_thomas_marcelino I don't use ARM for DB, uses it for all front end related deployment.
aaP_hareeshnarayan1982 In this case, on Ubuntu 22.04 I cannot install MariaDB nor Mysql. What to do? Upload a database in Docker and point it as remote?
[unknown] Before that you can try with Ubuntu 20.04, its the most compatible OS for aaPanel.
[unknown] It seems like AaPanel ships with the standard (x8/x64) version of MySQL. My best bet is that you need to either:
- Dockerized your own MySQL -arm inside the aapanel, or
- Dowload & compile MySQL-arm manually
- Purchase another (x86/x64) server just for MySQL
- Test & use anything else other than MySQL
esyede Good morning, I installed Ubuntu 20.04 and it ran fine, now Redis is missing, it just keeps loading... it doesn't install
I receveid this error in php
- Edited
Hello, please check if it is normal under Configuration? If it is not normal, please reinstall php
aaPanel_Kern I downgraded to Ubuntu 22.04
