Stealth
  1. Firewall problems should be caused by apt being occupied.
  2. Redis installs the latest version by default, whichever is actual
  3. OLS Have you added the website and configured SSL? If not, it will not listen to port 443.
SSL:
    1. on fresh VPS in 50%? Ok
    2. New Redis, but can´t run it... Pause icon nonstop
    3. Yes, website with SSL certificates, still Not Listening on random fresh installs. How resolve it?
      (on other VPS when no SSL site, there is still listening 443 port, very random)
      For example, this bug is funny 1-2 years minimum there:
      You open PHP and open the SSL 😃
      Stealth
      1. It is recommended that you start from the command line, check what is the reason, and provide redis run log at the same time
        /etc/init.d/redis restart
        tail /www/server/redis/redis.log -n 20
      2. Advice Not Listening Advice Try restarting openlitespeed, other VPS Do you check if there are other programs using port 443? if it cannot be resolved, The server makes a snapshot backup. first, if possible, please send it to kern@aapanel.com.
      3. Is it normal for you to change your browser or use the incognitance mode?
        Stealth
        Hello, execute this command to check whether it is running and listening on the port?
        ps aux|grep redis && netstat -tulnp|grep 6379
          Post link:
          Stealth
            14 days later
            Installed 3 more VPS today, all Redis is paused and still there the bug... Only restart with cmd line work (but I think after restart the VPS again paused).
              aaPanel_Kern Hi, can you give us your aapanel information? The server makes a snapshot backup first, if possible, please send it to [kern@aapanel.com](mailto:kern@aapanel.com).
              Post link:
              Stealth
