• Discussion
  • How to reset password for aaPanel Linux 6.x
I have had A login problem recently...
I fill in the username and password "but the login button doesn't respond"
when clicked it doesn't do anything
and I can't log in to ssh cause I closed the login with the password
    aaP_arshd
    Hello, what information does it prompt for unable to log in? Press F12 in the browser to go to the network interface, and then visit to check for any errors?
    are you want to telling about it or not
    check this error, but I don't understand it.
    Hello, use the ssh tool to log in to the server and execute commands with root privileges
    rm -f /www/server/panel/data/ssl.pl && bt reload
    If you cannot use the ssh tool to connect, please go to the server provider's website to use vnc
    aaP_arshd
    I use the ssh tool to log in to the server and execute commands with root privileges
    Now it working Fine.
    Thanks
    I forgot my AApanel password, and I followed the instructions, but I still can't login with the reset password.
    please guide me
    I use Ubuntu OS
      9 months later
      a month later
      I change admin password via bt command with bt 5, but i got error:
      EXECUTING
      Pls enter new password: myPassword32
        File "/www/server/panel/tools.py", line 801, in <module>
          bt_cli(clinum)
        File "/www/server/panel/tools.py", line 621, in bt_cli
          set_panel_pwd(input_pwd.strip(),True)
        File "/www/server/panel/tools.py", line 76, in set_panel_pwd
          result = sql.table('users').where('id=?',(1,)).setField('password',public.password_salt(public.md5(password),uid=1))
        File "/www/server/panel/class/public.py", line 2948, in password_salt
          chdck_salt()
        File "/www/server/panel/class/public.py", line 2925, in chdck_salt
          pdata['password'] = md5(md5(u_info['password']+'_bt.cn') + salt)
      TypeError: string indices must be integers
      Please help me, because i cant login to web panel.
        aaP_sayalupalagiemailnya
        Hello, is the username and password displayed correctly when executing the command bt 14 using the ssh tool?
        the server does snapshot backup first.
        Try to find under /www/backup/panel/ latest compressed files Then extract out to find the data/default.db The file cover /www/server/panel/data/default.db The restart the panel again whether can solve?
        For example, the decompressed file is stored in /www/backup/panel/2023-08-17/data/default.db
        cp /www/server/panel/data/default.db /www/server/panel/data/default.db_bak
        cd /www/backup/panel/
        unzip 2023-08-17.zip
        cp 2023-08-17/data/default.db /www/server/panel/data/default.db
        bt restart
        21 days later
        hello, I did not change my password but now it is not working. how can i reset it knowing that i do not have ssh access ?
          12 days later
          7 days later
          a month later
          3 months later
