PrestaShop installation requires the zip extension to be enabled.
md01
But this system seems to be developed using php. Do you have php turned off for migration?
Hi,
To solve my problem, maybe prestapyt is one of the solutions
Prestapyt is a library for Python to interact with the PrestaShop's Web Service API. (I have the possibility of generating an API key on prestashop).
Similar to PSWebServiceLibrary.php, prestapyt is a thin wrapper around the PrestaShop Web Service: it takes care of making the call to your PrestaShop instance's Web Service, supports the Web Service's HTTP-based CRUD operations.
Can you tell me how to integrate prestapyt with aapanel?
Thanks.
If you want to install it in a separate environment of the panel, you can execute the following command
btpip install prestapyt
Hi,
Thanks for your feedback.
We must allow the following outgoing & incoming connections:
HTTP 80 / HTTP 443 / FTP 21 / TCP 3306, all these types of HTTP requests must be authorized: POST, PUT, GET, DELETE, HEAD.
How can we implement it on aapanel?
We would like to know if the 5 methods GET, POST, PUT DELETE and HEAD are they accepted by aapanel?
How to do it?
Thanks
in aaPanel ,you can released in the [Security] page,
If you have a security group, you also need to be released in the security group
Does your database follow the necessary requirements?
aaPanel_Jose I have updated and
Basic Information
Version 7.3.22 Install Path /www/server/php/
php.ini /www/server/php/73/etc/php.ini
Loaded Core date libxml openssl pcre sqlite3 zlib bcmath ctype curl dom filter ftp gd gettext hash iconv intl json mbstring SPL session pcntl standard PDO mysqlnd pdo_sqlite bz2 posix Reflection pdo_mysql shmop SimpleXML soap sockets sodium mysqli sysvsem tokenizer xml xmlreader xmlrpc xmlwriter imap fileinfo memcached redis apcu imagick exif xsl swoole yac readline snmp ldap recode enchant pspell Phar sysvshm calendar gmp wddx sysvmsg ionCube Loader Zend OPcache xdebug
Database-driven
MySQL No MySQLi Yes PDO-MySQL Yes
SqlServer No PDO-SqlServer No Sqlite3 Yes
PDO-Sqlite Yes PgSQL No PDO-PgSQL No
MongoDB No
Buffer
Zend OPcache Yes Redis Yes Memcache No
Memcached Yes apcu Yes xcache No
Encryption and decryption library
Zend Optimizer No Zend Guard Loader No ionCube Loader Yes
SourceGuardian No Mcrypt No OpenSSL Yes
Iconv Yes
Image processing library
EXIF Yes GD library Yes ImageMagick Yes
Network Communication Library
cURL Yes Swoole Yes Sockets Yes
File and string processing libraries
Xmlrpc Yes FileInfo Yes Ftp Yes
Mbstring Yes bz2 Yes xsl Yes
Other third-party libraries
xDebug Yes phalcon No yaf No
