I just added a new website with ssl and instead of showing the content i get a ERR_HTTP2_PROTOCOL_ERROR error, no idea what is happening, all the other sites work perfectly, if i remove the SSL i get the default website, and if i remove the default website i get a 403 nginx error... im clueless, what is going on? i configured every other website the same way and they work
    aaPanel_Jose same error, uninstalled nginx and reinstalled and all the websites work except that one πŸ™
    this is the first website i try to add after updating to aapanel 6.5.7, if that helps :\
    Edit: Changed nginx for apache and getting the same 403 error (for that one site only and for apache)... like... what???
    (the 403 error is because the default site is set to none, but still no idea why is not redirecting to the correct website instead to the default one...)
    Ok, is a bug with the new version, im 99.99% sure now... removed a website that was working before and has no traffic (for testing stuff) and created it back, now im getting 403 error on that website too... is there a way to downgrade aapanel? ...
    Ended up reinstalling the panel, added the websites back, got the bug again, i think its because the SSL... removed all the previous SSL certificates and now it works, but due to the reinstalling of the panel, i cant see my old databases... is there any command to show the databases in the panel?
      LCDraws
      please check/www/backup/panel/ dir
      if there exist content overwrite the latest default.db to the data directory of the panel to restore
      just lite
      copy
      /www/backup/panel/2020-01-19/data/default.db
      overwrite
      /www/server/panel//data/default.db
        aaPanel_Jose ok, databases are back, but still cant create a new database... says the password is wrong, and all the databases, when i click on "tools" to check the tables, show 0 tables (altho the data and tables are there, they work, but i guess they are not connected correctly to the panel)
          2 months later
          aaPanel_Jose Hi Jose, it me again ^^
          I have the same problem here, it keeping showed like this
          and when i try to overwrite the default.db, disable SSL and it redirected me to another page that i added before.
          Give me some help please, thanks a lot.
            aaPanel_Jose i'm like: "How ?"
            For me it's still showing ERR_HTTP2_PROTOCOL_ERROR no matter what device i try to connect, actually i have uninstall memcached from aaPanel and php extession too.
            Could you help me find out what wrong with this πŸ™
              Connect with us: πŸ“¨ Telegram πŸ’¬ Discord Email: support@aapanel.com
