hasokeyk
let me check it, please wait
How do I create a DNS address?
hasokeyk
update dns_manager plugin will fix it
Thanks. So how do I update?
Thanks you very much.
I would like to support you int translating your aapanel to Turkish.
How can I help you in this process?
Can you help me if I can't reach my sites right now?
- Edited
hasokeyk
Sorry, we don't have the energy to translate other language packs at the moment. It's our current plan to optimize and develop new features.Thank you very much
and what's the problem with your site?
hasokeyk
whatβs the record value do you entry?
- Edited
ns1.istanbulallerjimerkezi.com.tr.
hasokeyk
you can set like this
host record : ns1
record value: istanbulallerjimerkezi.com.tr.
added when you refresh the page.
hasokeyk
i'am sorry, i understand it incorrectly..
If you need to set your server "a" to be the ns record server of the other server "b", you only need to add an A record in the server "a", and then modify the ns record as "a" in the other server "b" Server resolved domain name
If you need to modify your server's ns record, you need to modify the two ns records of the image.
