Ohh sory, an now Login Failed, where do I see the login password ? Please
    I can send email but I can't receive it in the roundcube, what can it be? Already set up the email server and everything is ok
    2 months later
    aaPanel_Jose
    $config['plugins'] = array('attachment_reminder', 'autologon', 'emoticons', 'password');
    $config['password_driver'] = 'sql';
    $config['password_db_dsn'] = 'sqlite:////www/vmail/postfixadmin.db';
    $config['password_query'] = "UPDATE mailbox SET password=%p WHERE username=%u";
    I am using this but the password is not encrypted. How to encrypt?
      a month later
      dedyk That happened to me too. When changing the password, the user is unable to log in to the email. When checking the database, the password is recorded without encryption.
      When trying to activate "dovecot" encryption I get the message: "Could not save new password. Encryption function missing."
      Checking the error log, I realized that PHP is not able to write to "/ dev / null". I already changed the file permissions, but it has no effect.
      I also tried to edit the password.php file, changing the destination "/ dev / null" to "/ tmp / null" and it also has no effect.
      10 days later
      aaPanel_Jose It redirects to the site itself with the https.. Is it the SSL certifcate issue? Site's registrar is Cloudflare and using Cloudflare's SSL certificate.
      I just want to import the old emails into the new ones, on Horde there's an option to export the emails into mbox format and import them again, is it in Roundcube the same?
      • Update: I applied Let's Encrypt SSL to teh webm.domain.com and I can access Roundcube now, but how to import the mbox emails dump from the file I saved from the previous host?
      5 days later
      hi sir
      i installed an aapanel only for RC webmail server.
      the problem im facing is that when i'm trying to add domain name to mail server i got an error "A record parsing failed"
      how can i solve this??
      the other problem is i cant login into RC because i dont know whats the user and password
      server address
      mail.pardisjam.net
        a month later
        Hello, I am having problems like other people when installing the password plugin, it works but when making the change, the account cannot be accessed again with that password, and it is necessary to enter and change it from the aapnael mail manager.
        How can I check what is wrong? the key is probably being incorrectly stored in the database.
        password.log
        [10-Apr-2021 02:04:15 +0800]: <t6441mc0> Password changed for user diego@hmundo.com (ID: 1) from 190.16.107.66
        error.log after login try
        [10-Apr-2021 02:13:59 +0800]: <34odd2rh> IMAP Error: Login failed for diego@hmundo.com against localhost from 190.16.107.66. AUTHENTICATE PLAIN: Authentication failed. in /www/wwwroot/webmail.hmundo.com/program/lib/Roundcube/rcube_imap.php on line 200 (POST /?task=login&action=login)
        thanks
        2 months later
        @aaP_diego.de#19787
        Having the same issue, please someone help
        a month later
        I installed roundcube according to the instructions, but after entering the address I get information
        Sorry, this page could not be found
        4 months later
        21 days later
        Pleases update RoundCube to 1.5.0 version supported php 8.0 no old php 7.3!!!!!!!!!!!!
        9 months later
        How can a panel like this, wonderful, not have a native integration with Roundcube, is there any way to install it without having to edit anything?
          22 days later
          i already created website 1 week ago and now i am adding roundcube email
          i am getting error
          The site you tried to add already exists!
          how to add roundcube in already created websites...???
