8 months later
Are you guys giving up with aapanel? I've come across two bugs that seem to be really old.
Not work, please check help me again.
It never worked for me, I gave up, I removed it and I'm using the warning now via email implemented in this last update.
4 days later
aaP_edcelmanuel9
Yeah I get your point, I like it aaPanel - just worries me a little that there's bugs that's been outstanding 2+ years!
10 days later
it's working with me, you have to give the bot permissions to write messages by entering the bot settings in telegram.
4 days later
Can send backup file via telegrams...?
recommended that you check the Alarm in the settings
9 days later
Doesn't work What message is displayed? Is it the latest beta version?
Execute the command bt 22 to check the log
aaP_anarbaoui
Now i can set the telegram setting with successful, but send notification doesn't work with me.
Information about my system and aapanel version :
aaPanel LinuxStable 6.8.29 (LATEST)
System:Ubuntu 20.04.5 LTS x86_64(Py3.7.9)
when click test buttom i receive this is error {"status": false, "msg": "send complete, send result: False."}
and when check Alarm Log:
Title:[ SSH login warning],method to informe:[Telegram],recipient:[ success:Fail ] 2023-07-12 10:24:06
196.xx.xx.xx(Client IP)(Unknown IP attribution) Title:[aaPanel notifications],method to informe:[Telegram],recipient:[ success:Fail ] 2023-07-12 10:24:06
Title:[ Panel Login Alert],method to informe:[Telegram],recipient:[ success:Fail ] 2023-07-12 10:08:29
