SSL can not auto renew
Yes, i can confirm that SSL not working from last update. First SSL is not renewed auto then when i done it manually still not working. I bought SSL for 5$ on year to websites continue showing.
Kiril Hi, he had a scheduled task for renewing the SSL certificate, did you remove it?
- Edited
aapanel_power No, cron working.
Log:
ACME_NEED_RENEW
ACME_RENEWING
|-Creating order..
|-Getting verification information..
|-Verify the dir:/www/wwwroot/hostname/public/.well-known/acme-challenge
|-Verification type: http-01
|-Verifying domain name..
|-1 Query verification results..
|-Verification failed
|-Data validation failed and the CA was unable to get the correct captcha from the authenticated connection.
then i removed ssl and run manually then renew for 90 days but still show no ssl, then i bought SSL because it is server in production and doesn't have time to check errors and fix it
