• Support
  • PM2 Manager - Project Restart Issue
Hello sir,
in PM2 Manager 5.0 in Project List restart not work after update
its show error 😀
Sorry, something went wrong:
File "/www/server/panel/pyenv/lib/python3.7/site-packages/werkzeug/routing.py", line 1945, in
can u help to fix this ?
aaPanel_Captain
raise NotFound()
File "class/panelPlugin.py", line 1992, in a
return eval(execStr)
File "", line 1, in
File "plugin/pm2/pm2_main.py", line 524, in Restart
if result.find('✓') != -1: return public.returnMsg(True, 'Project [' + get.pname + '] has been restarted!')
AttributeError: 'tuple' object has no attribute 'find'
    technothumb Execute the following command on the command line to see if there is a project name, the error prompts that the project name cannot be obtained
    pm2 list
      8 days later
      aaPanel_Captain
      this is 100% working fix for error in pm2 which starts with:
      Sorry, something went wrong: Traceback (most recent call last): File "class/flask_sockets.py", line 30, in call
