Hello. When configuring FTP Storage, I get the message "Api data verification failed". Is there any solution to this error?
Thanks
Thanks
joker399
Please check the account password and FTP IP port you entered are correct
aaPanel_Jose
Hi Jose!
Today I have this problem too... I have good all entered and not first time using FTP backup plugin. I re-created again with new name and password and again this.
I found the problem, the VPS at Upcloud have a hardware firewall and a port 21 is disabled by default...
Maybe help this for others...
There was a similar problem, it turned out that the folder for files on the FTP server was deleted, recreated it and everything was solved. I would like more information to be displayed instead of the incomprehensible "Api data verification failed"
Hi, thanks for the information, we will optimize it.
i have similar problem with this.. how to fix ?
ip firewall was active for
21/tcp ALLOW Anywhere
22/tcp ALLOW Anywhere
80/tcp ALLOW Anywhere
888/tcp ALLOW Anywhere
39000:40000/tcp ALLOW Anywhere
mzitech
It is recommended to check whether your server can connect to ports 20, 21, 39000-40000 of the FTP server?
telent xxx 21
yes can connect any fix ?
*that ip server i was hide xxxxxx
telnet xxxxxxxxxx 21
Trying xxxxxxxxxx...
Connected to xxxxxxxxxx.
Escape character is '^]'.
220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
220-You are user number 1 of 50 allowed.
220-Local time is now 16:29. Server port: 21.
220-This is a private system - No anonymous login
220-IPv6 connections are also welcome on this server.
220 You will be disconnected after 15 minutes of inactivity.
when check can connect to port 21 only
mzitech
Post link:
hi . i can't do that cause this server with not snapshot and i have risk data. but i can give any log or make some command for that..
Can't directly see the problem, can't directly solve it
check email.. thanks
this i saw 'Api data verification failed'
how to fix this.. make trouble for backup.. and waiting one drive plugin so long available live at aapanel.
mzitech Did you tried with sftp option checked? I had connected with bunny storage and is perfectly working.
already try both still same result say popup error Api Data Verification failed
mzitech Which service are you using? did u checked the ports are opened?
