Is it better to use ubuntu to have these settings? Using "centos 7" is a problem when using webp
    roniel
    It is a way to add custom modules when you compile~ It has nothing to do with the system version.
      how to add this module to existing nginx server
        JAY You can uninstall nginx and reinstall with the module. I did it this way.
        8 days later
        Can help with the process tutorial to install nginx plus headers module?
        @aaPanel_Jose
        can you have make a option while installing nginx have option to select modules and install and have a option under nignx app configuration option to disable and enable modules
          2 months later
          Did anyone take the test with this module?
          Is there really a difference in page loading?
          a month later
          a month later
          i installed ngx_pagespeed module as per upper tutorial but when i check my domain header in chrome or any browser ngx_pagespeed not showing.
          2 months later
          deewinc Hello, this is the tutorial to add the extension, add the extension how to use, you need to learn yourself
          2 months later
          its not working any more can you make it automation
          4 months later
