When i try to access terminal from panel is showing this error . how can I solve this
terminal error
- Edited
samjoel1911
take that....:
https://www.aapanel.com/forum/d/2161-terminal-errors/7
Execute: btpip install paramiko -I
and restart the Panel
whenever i tried to open teminal it gives be below error. any suggetions ?
piyush
could you tell me what operating system are you using? Let me check
Please try to press enter in the terminal to see if you can reconnect
i am using CentOs 7.8.i have tried pressing enter in the terminal but no luck
facing the same issue with Centos 8.
I tried
but the same.
elearnnow
Can I log in to your panel to check? If possible, please send your panel login information to jose@aapanel.com I will arrange a time to check for you
piyush
Hi I am facing the exact issue when my terminal remains inactive for like 5 seconds. Is there any fix for this?
aaPanel_Jose
Thankyou
yashris Hello, please print out the screenshot of your error. Let me check
Hello aapanel_sniper , please check this. Thanks!
- Edited
yashris
Hey, hello, please go to your server to check this file: (/etc/ssh/sshd_config).
‘# ClientAliveInterval 30’
‘# How many seconds does the client send a heartbeat data to the service.’
’# ClientAliveCountMax 1800‘
‘# How many seconds does the client fail to respond, and the server automatically disconnects the connection.‘
If the following parameter is already enabled, please try to increase its value.
If it is not turned on, please try to reinstall ‘openssh’ to solve this problem.
aapanel_sniper
I tried increasing the value and re-installed openssh as well. I also restarted ssh service.
Still the same issue!
What else can I do? Thanks!
yashris For this I am very sorry, you may need to use other brands of terminal testing. If the problem still exists, you can consult the vps service provider to see if there is a solution.
aapanel_sniper Okay. Thanks!
This bug got fixed in the new update. Thanks Developers
yashris Hello, just solve it. If you encounter any problems next time, post directly on the forum
aaPanel_thisyear Sure, thanks!
