aaP_tuong10893
Hi,
You can explain your question directly here and provide screenshots. Please hide your personal information.
Mail server problem with ngnix
when i use the command in cli then i can enable ngnix on GUI
when i enable ngnix on web then i can access my webmail
Hello, I suggest you tell us what configurations you have added? The default mail server has no connection with nginx.
Are you using the same port? Do you use nginx proxy mail server?
how can i check what you said. this is my first time using aapanel
I have purchased your lifetime license, is there any way to support me?
Hello, webmail is a website that uses services provided by nginx+php. It is normal to enable nginx to access it.
But in cli I have to use the command systemctl stop ngnix then I can use ngnix on the web. So can you tell me what the error is?
Hello,
It is recommended that you check whether there are multiple nginxes in the system.
Reference Documents
https://www.aapanel.com/docs/faq/Service_Manage_Commands.html#nginx-problems-and-solutions
