aaPanel_Kern yes, by default it's listenning, it's haven when i follow security risk from dashboard page.
My Port 22 Blocked after Follow Security Risk
https://dnschecker.org/port-scanner.php
Check if it can be opened
aaPanel_Kern it's open kern.
any clue kern? i must login to portal provider to access terminal, in aaPanel i can't login terminal.
Hello, can you connect to other software? Or try restarting the ssh service
aaPanel_Kern i'm just use aaPanel terminal and normal port *80 . not other software. i have done to restart server, nothing to work.
Post link:
Detailed problem description:
aaPanel_Kern right, sending.
aaPanel_Kern sorry kern. My Lead not pleasure to share details. last i have to change port 22 to 6666 like below
may you direct me, how to?
It is recommended that you use this port
aaPanel_Kern so change again from ssh port 6666 to 22 again?
你好,
没有必要改了吧,就使用6666端口是否可以?
aaPanel_Kern i can't use it, even 22 or 6666, i don't know the problem is.
Hello, have you modified any configuration? Is key login enabled?
Hello,
You can check whether there are any related configuration and configuration files for ssh?
aaPanel_Kern where and what i must do to check kern?
Hello,
It is recommended that you check the modified files
/etc/ssh/sshd_config and other files
