• Support
  • Failing to renew SSL certificates Let's Encrypt
I am running aaPanel 7.0.13, but the problem exists since version 6.x.
The Cron certificate renewal says the Let's Encrypt SSL certificates were renewed, but in most of the cases, they are not.
Only in rare cases one or another certificate is effectively renewed.
This is the log for the SSL renewal for the main website:
This is the log for the renewal of the SSL certificate for the domain hosting the aaPanel:
But at Websites tab it shows the renewal did not succeeded:
Any idea on how to fix?
    4 days later
    a month later
    Auto renewal error last version....
    a month later
    • Edited
    The problem to automatic renewal certificates still is happening at aaPanel version 7.0.16, but the error message now is different.
    Manual renewal is working normally.
      Hello, you can ban SSL first, then reapply, and let its records be normal, and it will be automatically verified next time.
      Nanno
        When you say "ban SSL" are you saying "Disable SSL", and after apply to a new certificate?
