Hi, I'm a new user at aapanel, something has been confusing me for the past 2 days.
I have several domains and they run smoothly without any problems. The problem only occurs when I access the domain usinghttps://www.domain.TLD and it all points to the wrong subdomain.
This server could not prove that it is www.domain-xxx.tld; its security certificate is from domain-yyy.tld. This may be caused by a misconfiguration or an attacker intercepting your connection.
What should I do to fix this ?!, Thank you in advance.
  • aaPanel_Kern replied to this.
  • Hello, are all websites deployed with SSL? If not, please deploy SSL
    When using https, SSL must be deployed, otherwise it will jump to a website with SSL deployed.
    aaP_pancadewa
    aaP_pancadewa
    Sorry my mistake, I forgot to put the www subdomain into the "domain manager" on the main domain. It's running smoothly now. Thanks for your feedback.
