Hello,
I receive telegram notifications every night indicating SSH connection attempts each time between midnight and 1am.
I have no script running at this time. I can't find anything in the journalctl, and I can't find anything in /var/log/auth.log either
I also blocked port 22 on the firewall, so this is not a remote attempt.
I don't know where to look to find the cause of the bad connections
the telegram notif is :
SSH login failure alarm<br>>Server:aaPanel Linux panel<br>>IPAddress: IP Server(Internet) IP Server(Internal)<br>>SendingTime: 2024-12-24 00:18:55<br>>Notification type: SSH login failure alarm<br>>Content of alarm: <font color=#ff0000> Login failed more than 30 times in 1 minutes</font>
    Hello,
    The IP 82.64.xxx.xxx is my IP. Even if I turn off my box, I still have connection attempts that continue. 🙁
    Thank you.
      aaP_ludovic.leonis
      You can check the SSH logs to see if there are any records of these connections. Or you can try changing the SSH port to see if there are any connection records.
      Hello,
      changing the port did nothing.
      The lines remain the same and are really updated every second. However, for this I do not have an alert via telegram. Is it normal not to see more than the 7 lines present? Why do I not see the lines of the attempts that there are during the night and for which I receive telegram alerts?
      Thank's
