Hello, do not enable these extensions directly. You can go to the Install Extension interface to install mbstring. Other extensions are enabled by default. You can check PHPinfo.
There should be a display problem with phpmyadmin. Is it normal to try restarting the web service? Also use the browser in incognito mode to access
PHP not working well, some missing extensions, and phpmyadmin is blocked 405
all right, imma try it from beginning
installed it
install LNMP in first visit server
done
navigate to terminal and try PHP (it get stucked) except PHP -v
installing mbstring and another needed
and when i installing fileinfo extension it get hang
i know i know if my resources server is too 'low', but i think it can for installing fileinfo extension, right?
- Edited
- Best Answerset by aaP_iqronegoro0
Hello, the server configuration is too low. It is recommended to use Linux Tools tool to add 2048MB SWAP.
thx for the response, i'll try to do it, I'll be in touch
Hei, it work well, damn it why i didn't thinking it earlier, thank you!
hei just wanna ask, how i can enable restriction this open_basedir function?
i have tried to edit fpm PHP file, or in php.ini pointing to my public project folder, but it still same
Thank you
nvm, i just have to comment file in public/.user.ini, and now the route cannot be found, all 404
may i know why i cant install php8.3-fpm? but when installing 8.1 vers, there is found the package?
is this right ?
idk why there is no sites-available and nginx folder at /etc, i have compile install but it still same,
its worked with this code, earlier i add it in config but I'm wrong
Hello, is the problem solved? aapanel does not support using apt to manage nginx php
Does the website log contain any relevant errors?
all clear, maybe i miss understanding how aapanel managing nginx, and my low skill too, but I'll keep update for someone who may be experiencing the same issue until my deployment success
All right my app now up and can accessed, a miracle!
summary what i do to deploy my inertia app that may be useful for ppl who facing same issue
- install lnmp default
- configure PHP in app store, to tab disabled functions, and disable exec, passthru, system, proc_oci, putenv, and some (i forgot)
- installing extension like fileinfo, mbstring and into
- go to terminal in folder and setup the app, like npm i and composer install (don't forget to update the composer first), generate new key
- setup .env like changing database and migrate it
- install PM2 / nodejs in appstore, maybe you can use nvm instead and use node version that compatible to your project
- go to website and create new project PHP in PHP Project, configure to your domain and folder...
- open the site modification website, go to site directory, and pointing running dir to /public, and go to URL rewrite tab, write this configuration
location / {
try_files $uri $uri/ /index.php?$args;
save it - try access your website
thx for your assist too
Hello, thank you for sharing
Hello, how i can deploy my php native website now? i have create subdomain
http://audancer.rynn.fun/
but it cannot find, i just deploy it and set the directory project to root folder, i have index.php too, may i missed something?
my bad, subdomain need to wait to propagate online
but when i created my first subdomain it online instantly, bruh
when i accessed the subdomain, it not serve correct page, instead it serve my first website! its hilarious. when i open it in PC it show correct website, but when i open it in handphone, it keep showing first website.
may be related to dns behind this problem
Hello, please deploy SSL for the website. This is caused by using https access.
