The name is starting, it may take more than 1-5 minutes...
gogs_zaTx Pulling
gogs_zaTx Error Head "https://registry-1.docker.io/v2/gogs/gogs/manifests/latest": unauthorized: incorrect username or password
Error response from daemon: Head "https://registry-1.docker.io/v2/gogs/gogs/manifests/latest": unauthorized: incorrect username or password
bt_failed
docker (one click) install not working
also could you add https://docs.gitea.com/installation/install-with-docker is much better than gitlabs
Hello, have you set up a Docker account and password?
Thanks for your feedback add gitea
aaPanel_Kern thank you for your help and this amazing panel I would like to invest into it in the future
also I got this on one of our other servers "ERROR: An error was detected in the configuration file. Please solve it before proceeding
nginx: [emerg] "fastcgi_cache_key" directive is duplicate in /www/server/panel/vhost/nginx/0.fastcgi_cache.conf:1
nginx: configuration file /www/server/nginx/conf/nginx.conf test failed"
this happens when I add a domain I tried fixing it and nothing worked I haven't been able to publish a project due to this issue pls fix
- Edited
project is over due
fixed with "#fastcgi_cache_key "$scheme$request_method$host$request_uri";
#fastcgi_cache_path /www/server/fastcgi_cache levels=1:2 keys_zone=WORDPRESS:100m inactive=60m max_size=1g;
fastcgi_cache_use_stale error timeout invalid_header http_500;
fastcgi_ignore_headers Cache-Control Expires Set-Cookie;"
also could you pls remove all these aapanel advertisement were already contributing enough by having a subscription
Hi, can you provide screenshots?
aaPanel_Kern is on all the error pages and on the WAF system pages when a user gets blocked
I would also like to purchase a lifetime subscription. Would this be possible to transfer to a new server if my old server encounters some technical issues?
Hello, yes, go to the background of the official website to unbind, and then bind it to the new server
