"Can you get the file below? The file task.log in the /www/server/panel/logs folder is very large. Is it safe to delete it? Will it affect the panel if deleted? Please assist."
    "I have deleted it, it should have increased by 5.8GB, but it doesn't affect the storage capacity. Why is that?"
    Hello, please delete it in the recycle bin of the File interface.
    3 months later
    Hello, you can clear it directly, this is because of an error in the program, which makes it so big
    aaP_stefanoacciarri
