after updating to version 7.0.11 bt-task is always high.
Affected OS centos 7.9, debian 11, almalinux 8.8
    @aaPanel_Kern
    I have the same problem. Also I don't use dns module,
    Yesterday I clicked Fix on the panel and it did not fix the problem
    I use:
    openlitespeed + php 8.1 + mysql 8
    also openlitespeed needs this modules for stability:
    lsquic 3.3.2
    modgzip 1.1
    cache 1.66
    mod_security 1.4 (with libmodsecurity v.3.0.12)
      Hello, if it is BT-Task, you can restart aapanel first to solve the problem temporarily. We are dealing with this problem.
      aaP_admin470
      5 days later
