Hello everyone,
I would like to know how to add ssl itself panel, is there any way to do it?
I tried on port 2053 with the cloudflare dns. It can't be done it. When I change the domain name in the setting. the panel did't startup
    Hello, please can you modify these two files, certificate and key files?
    /www/server/panel/ssl/certificate.pem
    /www/server/panel/ssl/privateKey.pem
    Make sure this file exists and start aapanel after modification.
    /www/server/panel/data/ssl.pl
    aaP_jianshangwei
