Change Log:
  1. Add WP Toolkit Vulnerability Scan
  2. Add WP Toolkit Remote Manage
  3. Add language switching on Home and login interface
  4. Add local currency payment method
  5. Redesigned Monitor interface
  6. Redesigned Logs interface
  7. Redesigned Terminal interface
  8. Redesigned Setting interface
  9. Optimize display in some languages
  10. Fix the issue that caused backup errors after Cron editing tasks
    (If there is already a problematic task, please add it again)
  11. Fix some known issues
Tip: After upgrading, please press Ctrl + F5 to force refresh
This version will be updated to Python 3.12, please read this post before updating:
aaPanel operating environment upgrade to Python 3.12 Questions and answering
If you encounter problems during use:
  1. Take a screenshot of the error message,
  2. Provide the operating system and system version you are using and provide feedback to the forum.
Add language switching to the homepage and login interface
You have added language switching but removed the ability to upload custom translations, now they do not work
You also did not specify the folders where the custom translations and the original to be translated are stored
    This is the directory, backend and frontend. Please update to the latest test before translating.
    /www/server/panel/BTPanel/languages/
    /www/server/panel/BTPanel/static/vite/lang/
    Language configuration file: /www/server/panel/BTPanel/languages/settings.json
    aaP_valdeuscorp
      5 days later
      a month later
      aaPanel_Kern I have a ready translation into Russian for aaPanel Stable vers. 7.0.11. It is 100% complete and mostly adapted for convenient display. If necessary, the content can be checked for compliance and safety.
      I am already using it on one of the servers and during the week of active use, no problems have been found.
      https://github.com/blyamur/aaPanel-russian-translation
      I also made instructions and explanations.! You can use it for your needs
        8 days later
