I send info to your mail zhwyeah@gmail.com
Aapanel is not loading i did tried bt start bt 9,10,16, also tail -n 100 /www/server/panel/logs/error.log show nothing.
I have centos 7. I did install maria db 10.4 before that install mysql 8 and unistall mysql 8 then install 10.4. Php 7.3 and phpmyadmin 5.0.
I want to move here but if its sudenly stop i'm worred about it.
Can you change title to aapanel not start.
mahbub0047
    aaPanel_Jose changed the title to Aapanel not start .
    I just checked for you and found that your yum command cannot be used. If there is no data in your server, I suggest you reinstall the system. If there is data, please tell me and I will try to fix it for you.
    I did reinstall the server and install aapanel but after some time its again not start
      mahbub0047
      I tested on your server to be able to access port 8888, but it is not accessible on the public network. Please check if there is a security group on your server. If so, please release port 8888 in the security group
