Hello, no matter what I do, I can't open port 2087. I've tried everything, but it doesn't work. What do you think the reason could be?
Connection Error: Failed to connect to 192.168.1.666 port 2087: Connection refused(7)
do u check if your provider does not restrict the port
I logged in via SSH and I'm trying the ufw command, but I enabled it from the admin panel and it's not working.
Unable to connect to the remote server: Connection Error: Failed to connect to 127.0.0.1 port 2087: Connection refused(7)
    Hello, you need to have a program using port 2087 to provide services.
    I have already told you that the information displayed on the security interface is: whether there is a program using it and whether the system firewall has it open.
    UfukCH
