• Support
  • Adding more domains to existing Let's Encrypt SSL certificate
littleaotearoa
According to the file path it prompts, can you manually access it to display the content?
This is an error caused by Let's Encrypt authentication excuse not being able to access your website’s authentication file
    aaPanel_Jose
    Hi Jose,
    Thanks for your reply.
    I tried it again but now the panel just stopped at 'Creating order...' status for more than 20 minutes.
    I will try restart VPS + panel and see if it works.
    10 months later
    Disable the SSL in website setting and renew it again all the domain will show and then you can apply lets encrypt or any other SSL Certificate
    a year later
    i have same problem. use below command in ".htaccess" project file :
    <IfModule mod_rewrite.c>
    RewriteEngine on
    RewriteCond %{REQUEST_URI} !^/.well-known
    </IfModule>
    it's work for me.
    In some projects you have to refer the requests to the public folder. Because of this, this makes the folder inaccessible
    8 months later
    Is it possible to add domains and activate SSL without affecting the already issued SSL? On cPanel, this process can be completed seamlessly. However, I am concerned that every time I add a domain, Let's Encrypt might block the certificate re-issuance due to multiple attempts.
    Any insights?
      aaPanel_Kern Thank you. The initial requirement for adding a new domain and applying SSL to it is disabling SSL on existing domains. Is there an alternative method to avoid disabling SSL for existing domains while adding new ones? So, may be is there any SSH code available that can be executed or any other way?
        Hello, the ssl of the existing domain name will not be disabled
        webz
        • webz replied to this.
          aaPanel_Kern Although I am aware that it is not disabled, disabling the SSL is necessary in order to install SLL on a newly added domain. Without doing so, there is no option to install SSL on the pop window SSL install section.
          Do you understand where am I coming from?
            It is recommended that you intercept more information, but it is impossible to determine what the problem is
            webz
              Please see the screenshot. I hope this clarifies the problem I ma having. As on cPanel SSL installed independent.
              aaPanel I need to do following in order to install SSL on addon domain.
              Not supported, it is recommended that you try to create a new site with a different domain name
              What do you mean by not supported? I have a SaaS application installed and I need to add domains as registered customers. Everything is fine except for the trouble of adding new domains. Additionally, in order to support wildcard, I have to use DNS verification, which is another inconvenience.
              I am a loyal user of aaPanel without any doubt. In fact, even though I don't actually need it, I will still purchase the pack just to show my support. However, if you want to be a serious competitor to cPanel, the details really do matter. It may seem like a small issue to you, but because of this problem alone, I am still unable to cancel my expensive cPanel license!
              aaPanel is superior to cPanel in terms of being cleaner and providing faster response times. So please continue your good work but keep in mind that your competitor currently holds the largest market share and you are lacking in certain features!
                If your added domain name is in the same domain as the wildcard domain name, then there is no need to re-apply for SSL
                SSL must be reapplied if the domain name does not match
                It is recommended to create a new site in different domains
                webz
                  aaPanel_Kern and I not on same page.
                  • I do NOT want to create new site. I want to add domain to my SaaS website.
                    Only way to do this adding domain. I am aware of that no need to re-apply SSL but it is necessary to disable the SSL for the website to include newly added domain on SSL. I hope you understand.
                  So aaPanel compare to cPanel lack of this feature. If not let me know how to do this.
                  • cPanel I can addon domain and do not need to bother with other domains SSL
                  • aaPanel I have to disable the SSL first to apply SSL on addon domain.
                  I'm sorry I haven't used it, and I don't understand it
                  a year later
                  hey
                  hi
                  im unbale to activate the SSL for the main domain (domain.com & www.domain.com)
                  but I can easily activate ssl for subdomain example: files.domain.com or www.files.domain.com
                  getting this following error
                  appreciate your help
