• Support
  • Let's encrypt cron not finding SSL w/ less than 30 days
I have been having the exact same issue for a few months now (can't get an exact date).
I have a bunch of SSL certificates which are less than 30 days, using File verification.
CRON Script:
/www/server/panel/pyenv/bin/python -u /www/server/panel/class/acme_v2.py --renew=1
Logs:
|-No SSL certificate found within 30 days!
|-All tasks have been processed!
★[2024-09-19 09:24:03] Successful
Using panel version 7.0.9
    Post link:
    Detailed problem description:
    xemles
    2 months later
    Post link:
    aaP_chris
    2 months later
    Hi, thanks for your feedback we are currently working on fixing this issue
    a month later
    Hi! i have the same problem, any update for this?
    ★[2025-02-04 19:55:07] Successful
    I have got this problem...
    But too many domains ssl Expired
    20 days later
    Hello, what is the version of aapanel you are using? If it is not the latest version, please update it first.
    LynxX
    10 days later
    The problem persists event after updating aaPanel. I use to renew ssl manually as the cron is skipping all domains that have expiry of ssl within less than 30 days.
      Currently, only SSL will be automatically renewed within 30 days.
      If there is any problem with the data recorded before, it will not be re-renewed correctly.
      You need to update the panel to the latest version, then Disable SSL, and then re-apply for SSL to allow other records to be correct.
      medialab
