• Support
  • Maria DB installation failed v10.4
Hello there, my Maria DB installation of version 10.4 is getting failed with the below error log
`--2024-08-29 09:10:35-- https://node.aapanel.com/install/0/mysql.sh
Resolving node.aapanel.com (node.aapanel.com)... 172.67.171.7, 104.21.79.196, 2606:4700:3031::6815:4fc4, ...
Length: 58441 (57K) [application/octet-stream]
Saving to: ‘mysql.sh’
0K .......... .......... .......... .......... .......... 87% 30.4M 0s
50K ....... 100% 17.9M=0.002s
2024-08-29 09:10:36 (28.0 MB/s) - ‘mysql.sh’ saved [58441/58441]
selecting download node...
https://na1-node.bt.cn
Last metadata expiration check: 5:42:41 ago on Thu 29 Aug 2024 03:28:26 AM CEST.
Package libtirpc-devel-1.3.3-8.el9_4.x86_64 is already installed.
Dependencies resolved.
Nothing to do.
Complete!
Last metadata expiration check: 5:42:42 ago on Thu 29 Aug 2024 03:28:26 AM CEST.
Package cmake-3.26.5-2.el9.x86_64 is already installed.
Package libarchive-3.5.3-4.el9.x86_64 is already installed.
Nothing to do.
Complete!
Package libuv-1:1.42.0-2.el9_4.x86_64 is already installed.
Package openldap-devel-2.6.6-3.el9.x86_64 is already installed.
Nothing to do.
Complete!
当前已有数据库正在运行 停止安装!
|-Successify --- Command executed! ---`
I am however, able to install the version 10.11, but when I try to switch it to the 1004 version it's not working. Please give me a work around. I'm using Alma Linux 94.
    aaPanel_Kern --2024-08-29 09:17:11-- https://node.aapanel.com/install/0/mysql.sh
    Resolving node.aapanel.com (node.aapanel.com)... 104.21.79.196, 172.67.171.7, 2606:4700:3034::ac43:ab07, ...
    0K .......... .......... .......... .......... .......... 87% 20.2M 0s
    50K ....... 100% 111M=0.002s
    2024-08-29 09:17:11 (22.5 MB/s) - ‘mysql.sh’ saved [58441/58441]
    https://cf1-node.aapanel.com
    Last metadata expiration check: 5:49:12 ago on Thu 29 Aug 2024 03:28:26 AM CEST.
    Nothing to do.
    Complete!
    Last metadata expiration check: 5:49:13 ago on Thu 29 Aug 2024 03:28:26 AM CEST.
    Nothing to do.
    Complete!
    Last metadata expiration check: 5:49:14 ago on Thu 29 Aug 2024 03:28:26 AM CEST.
    Nothing to do.
    Complete!
    当前已有数据库正在运行 停止安装!
    This is the log i am getting after stopping and switch version.
    @aaPanel_Kern /www/server/mysql/bin/mysqld, Version: 10.4.32-MariaDB-log (Source distribution). started with:
    Tcp port: 3306 Unix socket: /tmp/mysql.sock
    Time Id Command Argument
    and execution log " 240829 10:16:19 mysqld_safe Starting mysqld daemon with databases from /www/server/data ./etc/init.d/mysqld: line 264: kill: (42612) - No such process ERROR! =========================================== The root password set 5800aec1196996d6 successuful 1 ERROR! MariaDB server PID file could not be found! Starting MariaDB.240829 10:16:24 mysqld_safe Logging to '/www/server/data/bigx11.online.err'. 240829 10:16:24 mysqld_safe Starting mysqld daemon with databases from /www/server/data ./etc/init.d/mysqld: line 264: kill: (43132) - No such process ERROR! ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (111) ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (111) ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (111) |-Successify --- Command executed! ---`
      aaP_vinayakbaranwal12
      Post link:
      Detailed problem description:
