• Support
  • [error] 48812#0: *585 FastCGI sent in stderr:
2024/08/26 08:00:43 [error] 46415#0: *31 FastCGI sent in stderr: "PHP message: PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 35655180 bytes) in /www/wwwroot/turknova.org/library/classes/class_database.php on line 124" while reading response header from upstream, client: 172.68.50.205, server: turknova.org, request: "GET /?p=home&pid=1 HTTP/2.0", upstream: "fastcgi://unix:/tmp/php-cgi-56.sock:", host: "turknova.org"
2024/08/26 08:00:46 [error] 46415#0: *31 FastCGI sent in stderr: "PHP message: PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 35655180 bytes) in /www/wwwroot/turknova.org/library/classes/class_database.php on line 124" while reading response header from upstream, client: 172.68.50.205, server: turknova.org, request: "GET /?p=home&pid=1 HTTP/2.0", upstream: "fastcgi://unix:/tmp/php-cgi-56.sock:", host: "turknova.org"
2024/08/26 08:00:51 [error] 46415#0: *31 FastCGI sent in stderr: "PHP message: PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 35655180 bytes) in /www/wwwroot/turknova.org/library/classes/class_database.php on line 124" while reading response header from upstream, client: 172.68.50.205, server: turknova.org, request: "GET /?p=home&pid=1 HTTP/2.0", upstream: "fastcgi://unix:/tmp/php-cgi-56.sock:", host: "turknova.org"
2024/08/26 08:00:59 [error] 46415#0: *31 FastCGI sent in stderr: "PHP message: PHP Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 35655180 bytes) in /www/wwwroot/turknova.org/library/classes/class_database.php on line 124" while reading response header from upstream, client: 172.68.50.205, server: turknova.org, request: "GET /?p=home&pid=1 HTTP/2.0", upstream: "fastcgi://unix:/tmp/php-cgi-56.sock:", host: "turknova.org"
2024/08/26 08:05:42 [error] 47167#0: *259 open() "/www/wwwroot/turknova.org/FİLM KAPAK RESMİ" failed (2: No such file or directory), client: 141.101.105.156, server: turknova.org, request: "GET /F%C4%B0LM%20KAPAK%20RESM%C4%B0 HTTP/2.0", host: "turknova.org", referrer: "https://turknova.org/?p=torrents&pid=10&action=details&tid=6"
2024/08/26 08:05:48 [error] 47167#0: *259 open() "/www/wwwroot/turknova.org/FİLM KAPAK RESMİ" failed (2: No such file or directory), client: 141.101.105.156, server: turknova.org, request: "GET /F%C4%B0LM%20KAPAK%20RESM%C4%B0 HTTP/2.0", host: "turknova.org", referrer: "https://turknova.org/?p=torrents&pid=10&action=details&tid=6"
2024/08/26 08:14:47 [error] 48574#0: *520 FastCGI sent in stderr: "PHP message: PHP Deprecated: Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set 'always_populate_raw_post_data' to '-1' in php.ini and use the php://input stream instead. in Unknown on line 0" while reading response header from upstream, client: 141.101.105.155, server: turknova.org, request: "POST /ajax/upload_file.php?action=upload_file&content_type=torrent_files&forumid=NaN&securitytoken=90540-1724660064-d8b86c8ddf9d9af418ffb1bb5c45e54d806cd0b4&qqfile=xbt-master.zip.torrent HTTP/2.0", upstream: "fastcgi://unix:/tmp/php-cgi-56.sock:", host: "turknova.org", referrer: "https://turknova.org/?p=torrents&action=upload&pid=21"
2024/08/26 08:17:55 [error] 48812#0: *585 FastCGI sent in stderr: "PHP message: PHP Deprecated: Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set 'always_populate_raw_post_data' to '-1' in php.ini and use the php://input stream instead. in Unknown on line 0" while reading response header from upstream, client: 172.68.50.36, server: turknova.org, request: "POST /ajax/upload_file.php?action=upload_file&content_type=torrent_files&forumid=NaN&securitytoken=90540-1724660272-90d9e0b8258c0258594ba508e62a0d697944932e&qqfile=MobaXterm_Installer_v24.2.zip.torrent HTTP/2.0", upstream: "fastcgi://unix:/tmp/php-cgi-56.sock:", host: "turknova.org", referrer: "https://turknova.org/?p=torrents&action=upload&pid=21"
2024/08/26 08:35:29 [error] 49055#0: *671 "/www/wwwroot/turknova.org/tr/index.php" is not found (2: No such file or directory), client: 179.43.191.18, server: turknova.org, request: "GET /tr/ HTTP/1.1", host: "vaycasino2l6.com", referrer: "https://51.255.85.181"
    Fatal Error: Specified key was too long; max key length is 1000 bytes
    You can find the specified php version in the app store
