- Edited
Shows that the addition was successful, but it is not displayed
Below is a screenshot shown
Hello, I suggest you provide more information or screenshots. I can’t tell what the problem is.
aaPanel_Kern After I added the reverse proxy, it showed that the addition was successful but did not show this rule, the content is correct, I reinstalled a different system, changed a different server, and it was like this
It is recommended that you provide more information or screenshots
Where did it come from and what was added?
aaPanel_Kern I suspect it's a bug in your panel
Hello, thank you for your feedback, this issue will be fixed in the future.
aaPanel_Kern Notify me when the trouble is fixed, thanks
Hello, will trying to update to the latest version 7.0.8 solve the problem?
aaPanel_Kern Solved, thank you
