I up ftp with mutil files, about 1000 files.
Only the first few files can be uploaded, then the message Connection attempt failed with "ETIMEDOUT:" appears.
upload ftp ETIMEDOUT
Hello, I suggest you check if the ftp service is running normally? Is the network normal? 21 Are ports 39000-40000 open?
aaPanel_Kern yes. network is ok. and already open passive ports 39000-40000
Does the server provider or other network equipment also need to be released? Are there any network related restrictions?
