Hello, i was use Nginx as proxy with my nodejs app, for example mydomain.com proxied to 180.xxx.xxx.xx:port
but it take 4seconds to return. when direct to IP like 180.xxx.xxx.xx:port its only 90ms
why nginx make it to slow ?
    Hello, if it is deployed on the same server, it is recommended that you use 127.0.0.1
    Need to go through the Internet through the server IP
    maulanadioo
      when access direct to my upblic IP with port, its fast, when trying to proxy it, to slow. am I make a mistake ?
      I dont know why, this is happend only for new domain, old domain still fast in same server and same code, only different domain. im using aapanel 7.0.7
        Hello, it is recommended that you check whether the new domain name resolves directly to the server's IP and does not use CDN, CloudFlare, etc.
        maulanadioo
