• Support
  • SSL is not working and a different directory is opened.
I renewed the SSL. There is no problem on the panel side. A 90-day certificate was created. However, when I try to access the address with https://, I get a certificate error and it opens a page in a different directory.
    Hello, I suggest you check the domain name of the certificate error? Is it a certificate for another domain name? Please check whether the domain name accessed is correct? Does the domain name’s A record point to the server’s IP?
    aaP_erdemkn
      Hello,
      I manage multiple domains and subdomains in a single panel. I have not had any problems so far. As you mentioned, I checked the IP and A records and did not see any problems. The address can be accessed as http://, but when I try to access it with https, it opens a different path in the service. This problem occurred after renewing SSL. Although I had renewed it many times before, there was no problem.
      aaPanel_Kern Hello,
        Hello, you must deploy SSL when using https, otherwise it will jump to a website with SSL deployed.
        aaP_erdemkn
