aaPanel_Kern Hello! The problem is that I don't know what package this web application requires. I bought it recently and I don't know what modules it requires πŸ™
Is there no way to solve this error friend?
    aaPanel_Kern this is what was in the package folder;
    "csvtojson": "2.0.10",
    "dotenv": "16.0.0",
    "exceljs": "4.3.0",
    "express": "4.17.2",
    "express-fileupload": "1.4.0",
    "validator-express": "6.14.0",
    "extract-zip": "2.0.1",
    "got": "12.6.0",
    "https-proxy-agent": "7.0.2",
    "jsonwebtoken": "9.0.0",
    "libphonenumber-js": "1.10.30",
    "mercadopago": "1.5.17",
    "mime types": "2.1.35",
    "moment": "2.29.4",
    "mysql": "2.18.1",
    "mysql-import": "5.0.26",
    "node cleanup": "2.1.2",
    "node search": "2.6.9",
    "nodemailer": "6.9.1",
    "pine": "7.10.0",
    "qrcode": "1.5.0",
    "qrcode-terminal": "0.12.0",
    "random string": "1.2.3",
    "sharp": "0.30.7",
    "stripe": "12.13.0"
    "devdependencies": {
    "eslint": "8.5.0",
    "eslint-config-prettier": "8.3.0",
    "eslint-config-xo": "0.39.0",
    "eslint-plugin-prettier": "4.0.0",
    "prettiest": "2.5.1"
    run the command:
    npm install csvtojson dotenv exceljs express express-fileupload express-validator extract-zip got https-proxy-agent jsonwebtoken libphonenumber-js mercadopago types mime moment mysql mysql-import node-cleanup node-fetch nodemailer pino qrcode qrcode-terminal randomstring sharp stripe
    to install all the dependencies and modules but when I try to start the node I get the same error that I need to click the "[One-key install]" button
    aaPanel_Kern ok okay friend, I managed to install all the dependencies and they appear in the list correctly! thank you!
    but I have another error now.. when I try to create the node project it is created normally but it is created off.. and when I try to turn it on it says "failed to enable"
      3 months later
