• Discussion
  • im trying to deploy my another next js project
here you can check my configurations
and this error im getting after that
when i select next dev its working fine but its not a production build why its not working with next start
    Hello, it is recommended that you deploy manually. Currently there is no compatibility with next.
    touseef
      If it cannot be started, it is recommended that you manually use the command line to deploy
      can you please do that for me?? or provide me the complete way to implement it
      because for me its not working
      It is recommended that you set the default node version on the command line first, and then refer to the official documentation for deployment.
