• SupportTutorial
  • aaPanel 7.x operating environment upgrade to Python 3.12 Questions and Answers
After updating the panel, the Website Speed ​​plugin was automatically installed. I don't have this plugin installed and I can't delete it. What's going on?
    Hello, please check the /www/server/panel/config/index.json file as per the file
    uscto
      ["nginx", "mysql", "php-8.3", "linuxsys", "firewall", "site_speed"], Remove "site_speed"? ?
      My aapanel can't start after update
      root@amlogic:~# bt
      /usr/bin/bt: line 361: /usr/bin/python: No such file or directory
        The tab https://xxx.xxx.xxx.:xxxx/database no longer shows anything for me; it turns completely white after the update. It used to appear normally before. What can I do to view my databases, create backups, or add new ones ?
          4ndr3
          use the ssh tool to log in to the server and execute the following command with root privileges:
          curl -k https://node.aapanel.com/install/update_7.x_en.sh | bash
            aaPanel_Kern I just tested it in Google Chrome's incognito mode, and nothing appeared; it was a blank screen. In the regular Firefox browser, it was also a blank screen. However, in Firefox's incognito mode, the tab loaded. What could be the issue? It was tested in Google Chrome's incognito mode, and it didn't load there either, showing a blank screen.
              Since the last update im having so many troubles with the panel.
              Webserver dying and not wanting to work day after day, suddenly MySQL takes 100% of the 16 cpu cores i have and hogs the server.. what is going on with this version please i need urgent help
                How to solve that's error came in Log Section" Please Guide ME Same Like That musliple error came on log section
                File "/www/server/panel/pyenv/lib/python3.12/site-packages/gevent/ssl.py", line 440, in read
                self.wait(self.read_event, timeout_exc=SSLErrorReadTimeout)
                File "src/gevent/
                hub_primitives.py", line 317, in gevent.gevent_c_hub_primitives.wait_on_socket
                File "src/gevent/
                hub_primitives.py", line 322, in gevent.gevent_c_hub_primitives.wait_on_socket
                File "src/gevent/
                hub_primitives.py", line 313, in gevent.gevent_c_hub_primitives.primitive_wait
                File "src/gevent/hub_primitives.py", line 314, in gevent.gevent_c_hub_primitives.primitive_wait
                File "src/gevent/
                hub_primitives.py", line 46, in gevent.gevent_c_hub_primitives.WaitOperationsGreenlet.wait
                File "src/gevent/
                File "src/gevent/
                hub_primitives.py", line 55, in gevent.gevent_c_hub_primitives.WaitOperationsGreenlet.wait
                File "src/gevent/
                waiter.py", line 154, in gevent.gevent_c_waiter.Waiter.get
                File "src/gevent/
                greenlet_primitives.py", line 61, in gevent.gevent_c_greenlet_primitives.SwitchOutGreenletWithLoop.switch
                File "src/gevent/
                File "src/gevent/
                greenlet_primitives.py", line 65, in gevent.gevent_c_greenlet_primitives.SwitchOutGreenletWithLoop.switch
                File "src/gevent/
                gevent_c_greenlet_primitives.pxd", line 35, in gevent.gevent_c_greenlet_primitives.greenlet_switch
                TimeoutError: The read operation timed out
                File "/www/server/panel/pyenv/lib/python3.12/site-packages/requests/adapters.py", line 486, in send
                resp = conn.urlopen(
                File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/connectionpool.py", line 799, in urlopen
                retries = retries.increment(
                File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/util/retry.py", line 550, in increment
                raise six.reraise(type(error), error, stacktrace)
                File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/packages/six.py", line 770, in reraise
                raise value
                File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/connectionpool.py", line 715, in urlopen
                httplib_response = self.
                make_request(
                File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/connectionpool.py", line 469, in make_request
                self.
                raise_timeout(err=e, url=url, timeout_value=read_timeout)
                File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/connectionpool.py", line 358, in _raise_timeout
                raise ReadTimeoutError(
                urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Read timed out. (read timeout=6)
                File "/www/server/panel/class/http_requests.py", line 103, in post
                result = requests.post(url,data,timeout=timeout,headers=headers,verify=verify)
                File "/www/server/panel/pyenv/lib/python3.12/site-packages/requests/api.py", line 115, in post
                return request("post", url, data=data, json=json, **kwargs)
                File "/www/server/panel/pyenv/lib/python3.12/site-packages/requests/api.py", line 59, in request
                File "/www/server/panel/pyenv/lib/python3.12/site-packages/requests/sessions.py", line 589, in request
                File "/www/server/panel/pyenv/lib/python3.12/site-packages/requests/sessions.py", line 703, in send
                File "/www/server/panel/pyenv/lib/python3.12/site-packages/requests/adapters.py", line 532, in send
                raise ReadTimeout(e, request=request)
                requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Read timed out. (read timeout=6)
                /www/server/panel/class/logsModel/panelModel.py:201: SyntaxWarning: invalid escape sequence '\s'
                if username and not re.search('-\s+({})\s+('.format(username),_line):
                [2024-05-26 15:28:05][DEBUG] - sub_path: logs "
                Hello
                I used to use mobile phone all the time, now it is very broken, nothing is in order
                There is no install button
                In some plugins
                In desktop mode, there are no buttons on the phone
                  bt 22
                  EXECUTING
                  /www/server/panel/BT-Panel:238: DeprecationWarning: setDaemon() is deprecated, set the daemon attribute instead
                  task_thread.setDaemon(True)
                  [2024-05-26 19:37:17][DEBUG] - sub_path:
                  /www/server/panel/BT-Panel:63: SyntaxWarning: invalid escape sequence '\c'
                  os.system("\cp -f {} {}".format(plugin_loader_src_file, plugin_loader_file))
                  [2024-05-26 19:37:35][DEBUG] - sub_path:
                  [2024-05-26 19:38:00][DEBUG] - sub_path:
                  [2024-05-26 19:38:22][DEBUG] - sub_path:
                  [2024-05-26 19:38:25][DEBUG] - Traceback (most recent call last):
                  File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/connectionpool.py", line 467, in make_request
                  six.raise_from(e, None)
                  File "<string>", line 3, in raise_from
                  File "/www/server/panel/pyenv/lib/python3.12/site-packages/urllib3/connectionpool.py", line 462, in make_request
                  httplib_response = conn.getresponse()
                  File "/www/server/panel/pyenv/lib/python3.12/http/client.py", line 1428, in getresponse
                  response.begin()
                  File "/www/server/panel/pyenv/lib/python3.12/http/client.py", line 331, in begin
                  version, status, reason = self.read_status()
                  File "/www/server/panel/pyenv/lib/python3.12/http/client.py", line 292, in read_status
                  line = str(self.fp.readline(MAXLINE + 1), "iso-8859-1")
                  File "/www/server/panel/pyenv/lib/python3.12/socket.py", line 707, in readinto
                  return self.sock.recv_into(b)
                  File "/www/server/panel/pyenv/lib/python3.12/site-packages/gevent/ssl.py", line 625, in recv_into
                  return self.read(nbytes, buffer)
                  File "src/gevent/hub_primitives.py", line 317, in gevent.gevent_c_hub_primitives.wait_on_socket
                  File "src/gevent/hub_primitives.py", line 322, in gevent.gevent_c_hub_primitives.wait_on_socket
                  File "src/gevent/hub_primitives.py", line 313, in gevent.gevent_c_hub_primitives.primitive_wait
                  File "src/gevent/hub_primitives.py", line 46, in gevent.gevent_c_hub_primitives.WaitOperationsGreenlet.wait
                  File "src/gevent/hub_primitives.py", line 55, in gevent.gevent_c_hub_primitives.WaitOperationsGreenlet.wait
                  File "src/gevent/waiter.py", line 154, in gevent.gevent_c_waiter.Waiter.get
                  File "src/gevent/greenlet_primitives.py", line 61, in gevent.gevent_c_greenlet_primitives.SwitchOutGreenletWithLoop.switch
                  File "src/gevent/greenlet_primitives.py", line 65, in gevent.gevent_c_greenlet_primitives.SwitchOutGreenletWithLoop.switch
                  File "src/gevent/gevent_c_greenlet_primitives.pxd", line 35, in gevent.gevent_c_greenlet_primitives.
                  greenlet_switch
                  raise value
                  httplib_response = self.make_request(
                  self.raise_timeout(err=e, url=url, timeout_value=read_timeout)
                    yuv41
                    Hello, updating aapanel will not affect the operation of the database. aapanel is an independent service.
                    It is recommended that you use phpmyadmin to check whether the database process is caused by too many processes?
