Displayed in developer mode of Chrome browser: GET https://1.1.1.1:8000/static/js/tools.js?version=6.8.33&repair=IaBoDsEHscDN6t7f net::ERR_TIMED_OUT
AttributeError: module 'lib' has no attribute 'X509_V_FLAG_NOTIFY_POLICY'
Post link:
Same problem.
root@xxx:~# btpip install pyOpenSSL -I
Collecting pyOpenSSL
Using cached pyOpenSSL-24.0.0-py3-none-any.whl (58 kB)
Collecting cryptography<43,>=41.0.5
Using cached cryptography-42.0.2-cp37-abi3-manylinux_2_28_x86_64.whl (4.7 MB)
Collecting cffi>=1.12
Using cached cffi-1.15.1-cp37-cp37m-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (427 kB)
Collecting pycparser
Using cached pycparser-2.21-py2.py3-none-any.whl (118 kB)
Installing collected packages: pycparser, cffi, cryptography, pyOpenSSL
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
aliyun-python-sdk-core 2.13.30 requires cryptography<3.3,>=2.9.2, but you have cryptography 42.0.2 which is incompatible.
Successfully installed cffi-1.15.1 cryptography-42.0.2 pyOpenSSL-24.0.0 pycparser-2.21
WARNING: You are using pip version 20.3.3; however, version 24.0 is available.
You should consider upgrading via the '/www/server/panel/pyenv/bin/python3.7 -m pip install --upgrade pip' command.
Umbu
Hello, is the problem solved? It is recommended that you describe the problem in detail
mv /www/server/panel/pyenv/lib/python3.7/site-packages/OpenSSL /tmp/OpenSSL_bak
bt reload
Tried these commands, but no fix. now my site is errror
ERR_CONNECTION_REFUSED
please help
Hello, please do not execute command operations at will.
The website cannot be accessed. Please check whether the web service is running normally?
- Edited
I also had the same problem as above, aapanel was very slow and continuously displayed error messages
Restarted the server but it still hasn't been resolved, yesterday I couldn't access the database, it kept showing the loading message..
treconyl
Hello, is it normal to use the ssh tool to execute the command and try again?
bt reload
aaP_hkrock2023 resolved for me! thx!
aaPanel_Kern This worked for me , thanks very much
mv /www/server/panel/pyenv/lib/python3.12/site-packages/OpenSSL /tmp/OpenSSL_bak
bt reload
please help me to solved this issue.
Hello, is the result of executing the command normal? What message does the error prompt?
