Hi Aapnel Support Enthusiasts,
Hope we are driving toward a good alternative product of cPanel.
Right now, I'm in a phase of Aapanel upgradation to aaPanel LinuxStable6.8.33 from Version 6.8.17.
Could you please guide me to a successful upgrade to the latest version of Aapanel? If there are any bugs you noticed in the following Oracle VM.Standard.A1.Flex 4 cores 24 GB machine.
Kindly, Tell me what necessary steps (in order) I need to follow to upgrade safely without any new problems. or not bricking the server.
Thanks In Advance,
AaPanel Enthusiast.
    Hello, before upgrading aaPanel, it is recommended that you take a server snapshot backup before upgrading.
    Even if aaPanel is unavailable, it will not affect the website
    achates
      Hey, Kern.
      Thanks for your precious time to reply to me. I understand that I need to take a backup, As it's recommended for every Massive change we make in our machine or server.
      Do we have Proper aaPanel Forum Guidelines/tutorials for this problem to be solved on the machine I'm working on?
      I wonder if there's a step-by-step guide for this Aapanel upgrade problem with all the necessary commands.
      If there's none, I might need to find a time-optimised solution for this to happen.
      I'll ask for a favor from you if you have the solution documentation ready with the rollback problem in case of any accidental server damage. So that I can easily get back to my previous version.
      I'd like to ask another question, does the Aapanel Developers team count my system architecture for the product? Or they are just building Aapanel for a particular underlying system architecture. Because I already have some compatibility issues with the current version of aaPanel in regards to the VM instance configuration of mine.
      Some of the plugins were not working and had bugs while running. I could open a discussion but I never raised any as I was seeing that Aapanel is just growing. Even though I'm in community version end-user of Aapanel, I could provide possibly a lot of improvements and bug reports regarding aApanel.
      As my workload is growing, So, I find myself dependent on Aapanel in the long run and I'm still loving Aapanel.
      So, I hope to keep holding on this product and architecting my system within the scope of Aapanel.
      I hope you understand, What I'm trying to say.
      Hope to get your kind support for now.
      Hello, taking a snapshot of the server is the most stable.
        Do you have any good tool suggestions for taking a snapshot to back up the server?
        I'd prefer a good user-experience tool for doing it.
        thanks in advance.
          5 days later
          Hello, it is recommended that you use the snapshot function of your server provider
          achates
