when I want to install one of the themes on my WordPress, I experience something like the following
Some problems when installing openlitespeed OLS on aapanel
Is it normal to install other themes? It is recommended that you check where this topic needs to be connected to where it went wrong
i found this problem when trying with openlitespeed on aapanel server, if with other web server it seems safe, can you check something about this
Are other servers consistent with this server's network? Same exit?
aaPanel_Kern yes, include on the same base server
already try it with os centos7, ubuntu22, almalinux8, if im try to using openlitespeed get it someproblem, but if I use nginx or apache it seems to run normally
It is recommended that you use nginx or apache first
