aaPanel_Kern can you give me a answer on my question then , with operation system
I have used centos errors ubuntu errors debian errors
I have installed everything 5 times the last 2 weeks and transferred every time 500 gig of data .
    It is recommended that after installation, you check that there are no problems before processing the data.
    The missing configuration file means you have not set up SSL for your mail server.
    The system firewall cannot be enabled. Is there any relevant firewall software?
    centos: firewalld
    debian: ufw
    leon
    • leon replied to this.
      With operation systems are recommended now .
      I have tried centos 8 , Ubuntu 20 . Debian 10 and 11
      So with operation system has to be good with no errors
      aaPanel_Kern Could you please tell me which operation system I need, and it works just fine
      After time more and more bugs :/ Not better panel, but going down...
      leon
      Hello, Centos 8 does not do any maintenance anymore. Centos 7 is caused by the installation of the new version of rspamd, which causes the python library to not get the process name correctly.
      It is recommended that you install the lower version manually, and if rspamd works you can ignore it
      Rspamd daemon version 3.1
