- Edited
I want change IP phpmyadmin to domain to increase security
Hello, do not disclose personal information.
The domain name can be set in the settings of the panel. After setting the domain name, the panel can only be accessed through the domain name. ip will forbid access to the panel. You can use the SSH tool to log in to the server and execute the command to cancel the domain name bt 12
At the same time, the A record of the domain name cannot open the proxy CDN
aaPanel_Kern i try to change ip with domain name but my domain point ip through cloudflare cpanel asks to enable ssl https on cloudflare already enabled but i cant access control panel via domain on cloudflare
it returns nothing
Using the domain name must be closed agent, and A record is pointing to the server IP, suggest A new access to special build an A record for panel
Why do you want to disclose your personal information?
aaPanel_Kern it's a temporary server ip I just tested, it doesn't affect security at all
i pointed then the issue of creating subdomains on cloudflare didn't affect anything i tried creating 1 domain on the control panel it's completely accessible to each other but create from Security to access the dashboard n[upl-image-previewurl=https://www.aapanel.com/forum/assets/files/2023-08-28/1693189408-101635-image.png] it's all error
close proxy
aaPanel_Kern why it can't support proxy
aaPanel_Kern if so is there any tool to block but their ip scan database phpmyadmin ?
if for example my path to phpmyadmin is exposed is there a way to filter and block the users they request continuously?
Hello, the link is randomly generated, it is not so easy to expose, you can set the system firewall to only allow your IP to access
