can you use cron to renew the certificate? just click the execute button.
[Help] Can't Renew SSL Certificate
I tried to delete the certificate and want to create a new certificate, but now I can't generate wild card certificate. :-(
Or maybe you can apply for other free SSL such as from zerossl and apply it from Other certificate tab.
Or it just like previous issue...
I don't know why, but the problem already solved by self
Thanks for the responds.
Hello logamid
How do you solve it? Can you share it?
- Edited
Cron this : /www/server/panel/pyenv/bin/python /www/server/panel/class/acme_v2.py --renew=1
Kasi
Please try to close the certificate and reapply
a month later
aaPanel_Jose I tried several times, delete the certificate and recreate it, and then somehow it generate the wildcards.
