JAY the way i do it its when i create the domain name in aaPanel, i simply add the www.domain.com on it as well on the time of the creation, then i dont need to do anything else, I also use the DNS manager, and my registar has the www added on the cname as well. This is my method, works perfectly on www or without it. Hope that helps you.
  • JAY replied to this.
    TheWormsUnited
    i really i dont know how to explain you are such a non understandable user iam able to access my domain on www.domain.com and domain.com
    i just need to redirect the domain from www.domain.com to domain.com as i dont want to usrs to access domain from www.domain.com
      JAY you are such a non understandable user
      Completely unnecessary, further more when you are the one that does not explain correcctly and myself just want to help you out. No worries, me and myself keep out of your understandable posts.
      JAY
      redirect from www.domain.com to domain.com should be no problem. can i login your panel or use remote tools to check it for you?
      14 days later
      JAY
      I have no way to reproduce this problem. I checked and judged that the two domain names are the same to trigger this error, but www.domain.com and domain.com are obviously not the same.
      13 days later
      I have the same problem.
      I have a domain added a domain domain.com to aapanel
      After that to solve the problem I added another domain www.domain.com and redirected this domain to
      https://domain.com
      The redirection worked but we still have a third domain:
      https://www.domain.com
      This combination will not be redirected. It will be redirected to the index of the first website created on aapanel. Adding this code to .htaccess doesn’t solve the problem.
      RewriteEngine On
      RewriteCond %{SERVER_PORT} !443$
      RewriteRule .* https://%{SERVER_NAME}%{REQUEST_URI} [R=301,L]
      RewriteCond %{HTTP_HOST} www.domain.com$ [NC]
      RewriteRule .*$ https://domain.com/$1 [R=301,L]
      Thank you for the great script!
      Do you have a solution for this problem?
        JAY same problem. When I open www version of my site it'll b open another site from aapanel
          v1sh4l
          This problem may be caused by your www.domain.com not deploying ssl but using https access
          aaPanel_Jose
          the same i was telling from day one. now domain is working on both www.domain.com and domain.com its not good for seo i want domain to open only on domain.com
          so i need to redirect from www.domain.com to domain.com. which is not happening from panel
            aapanel_user
            its working because your domain was registered as www.domian.com and this option may be removed as new redirect option is enabled.
            v1sh4l
            brother i know how to fix i can use htacess and CF and other ways iam trying to fix the one in panel.
              JAY add www.yourdomain.com in domain manager of main domain
                v1sh4l
                do you understand what is title for this bug,
                if i add www.domian.com in domain manager website open www.domain.com and domain.com
                a month later
                This problem is happening to me too, when accessing my blog https://meublog.com it works normal, more as stated in the browser https://www.meublog.com it does not work from the error. Why does this happen, and how to fix it ???
                I confess that I even stopped using this panel because of this error? but now I'm back and I want to try to fix it, but how do you do it ???
                  joel
                  i reported many times and stopped asking about this and moved site to plesk
