failed to activate
start > node . Running cleanup before exit. > start > node . Running cleanup before exit. > start > node . Running cleanup before exit. > start > node . Running cleanup before exit.
    This looks normal. Is it the same as recommending that you run it using the command line?
    The node path of the panel, please use the full path: /www/server/nodejs/v16.14.0/bin/
    Replace v16.14.0 with your node version
    aaP_mohamedeldony3
      Are they also built using aapanel? Is there a link?
      Also check your settings are correct? Are there other options for Run opt, and if so, is it normal to choose others?
      aaP_mohamedeldony3
      7 months later
      try to use the custom command "pm2 start app.js". I try to add pm2 and it works
